Ok, I'm not sure what all the 3Lduratec.com long block comes with as far as equipment so here goes. The oil pan, if it is the 3L oil pan, it will NOT bolt up to the MTX-75. the MTX-75 bell housing will match up with all the bolts but the last 2 on the bottom. this isnt really a problem because the top bolts are enough to hold it all together, but modification of the oil pan is up to you. You will probably break some of the bolts, its a given and unpredictable as to which bolts may or may not break during the swap, so be prepared to go to home depot or Fastenall for some hardware. As you said, a clutch kit is a must, if you are tearing it down that far, you might as well. Fidanza flywheel is also something to consider since you have to swap that out anyways, and while you have it apart a torsen or a quaife is also a good idea, provided the funds for such upgrades are available. I dont know if the 3Lduratec.com long block is tapped for the 2.5 knock sensor, look into that as well, if not it is an easy fix with a visit to car quest. I assume you are using the 2.5L intakes, if so new gaskets (UIM, LIM, TB, IAC, EGR) will be required. Also, while the engine is out of the car MSDS headers are a VERY worthwhile upgrade, trust me...putting headers in a FWD car while the motor is still in is no picnic. If you plan on using SVT cams, up to you, then you will need timing cover and valve cover gaskets as well. If you plan on using the stock crank dampener i would recommend upgrading to the dual mode dampener or DMD. If not, i would say got for an underdrive crank pulley if you can find one. Thats a decent upgrade. Also solid motor mounts to reduce travel in the transaxle while it is mounted in the car. You can make them yourself with your stock mounts by filling them with urethane or you can buy them from Nautilus. This is just a start to all the upgrades and modifications you can do to make your life easier in the long run. All the resources, including tutorials, you will ever need are here on CEG. Check out Blu's thread for a detailed step by step walk through of the swap.
