I am new to this! However i just acquired a 99 Contour V6 Automatic. I am needing the mount that attaches in front bottom on crossmember? Any ideas how to remove or even find the mount or insert? As i was tightening my O2 sensor from the bottom the engine transaxle moves. It moves from the mount i described. I tried removing the mount. loosened the center bolt the two frame bolts, seems the cooling fans are in the way to remove bracket. Put back as is. Please help. I read alot of this stuff. Now i needed to Post.
