nope the escort x50 fit right above the mirror... passenger couldnt use the visor tho... just used an escort hardwire kit and tapped the sunroof motor
Did the hardwire kit have an inline fuse? It would need to be a small one but i would feel better if i had one to protect my bloody valentine1. Im going to mess with the 98 i have first before i take apart my baby.It should be just a ground and a power wire? Did you ground it with a screw or just to the ground wire on the sunroof motor? I will also do this for my GPS. Yummy it will look sweet! I will take full pics and show a how to,i just hope my how to works:crazy:
Ok tested on the 98.
Gently pry the switch cover off with a small flathead.
Then unhook the wires to the switch panel.
Now thats out of the way,unscrew the 2 screws holding the cover on.Don't pull down, slide out twards the rear of the car,as it is slid over the top of the sunroof motor.
Now i imagine that these are the wires i want to tap into? The only other wires are going to the sunroof switch. Only 2 wires going in but neither one is black! What i wonder is the power and ground?
I tested the wires.Purple is power,very strange! These pics are the actual install on my 99
I got a 3 dollar inline fuse from R. shack and used a 5amp fuse,since i will be running my gps and v1. The V1 calls for a 2amp fuse so......
Use a quick connector and tie in the fuse to the power.
I ran the wires through the headliner pretty easily,the 2 wires on the left are for the gps,and the 4 wire mess is the V1
If you chose to cut your factory V1 cord it has 4 wires,i found that green was power and red was ground! The other 2 are useless?
I chose to mount the gps in the upper left hand corner....
And the v1 cord going into the headliner.
I must continue in another post,im only allowed 10 pics.
