Wife's '95 SE ATX drains the battery (~0.36A) when sitting. With the key out of the ignition and doors open, the buzzer chimes like the keys were left in the igntion. Close the door, the chiming goes away, but the drain continues. Also, the key can be pulled out of the ignition switch in the run position and the car will keep running. So, I did the seemingly obvious and changed the ignition switch...results...same power drain and chiming with the new switch. Also, with the battery connected, I cannot remove the key from the new switch. If I pull off a battery cable, I can remove the key, but only at the off position as it should.
I'm kinda at a loss. Any ideas?
