zorrex is right
zorrex is right
It is a 13mm or 1/2 inch ( they are so close either will work and you might find a wider selection in 1/2 inch) , get the longest one you can, the tensioner is pretty stiff. If I remember correctly you will push on the wrench (clock wise) and then with the free hand roll the belt off of the crank pulley.
