SVTMiG
Wondering if anybody's ever seen similar...Clutch on stock '00 2.5 is a spec stage 3 (PO installed, don't ask) and has 25K miles +/-. I've had the car less than 2k miles, but the clutch has been good aside from being ridiculously overkill. So this morning I head out with no drama till 3-4 miles down the road cruising easy at 50 in 5th and I have no power transmission. NONE. No warning signs, slippage, strange noises, nothing. I parked it at a party store for now, gotta go fetch it later. While idling with park brake on, I picked a gear and ran the clutch pedal a few times. Where the friction point should be the rpm's flux 100-200 if that and only momentarily. Clues or starting point anyone???
Add on...
I was checking out more clutch posts and other than I'm shocked that I didn't feel slip gradually I won't be surprised if the clutch disc is just shot. So, if I end up replacing the clutch...How bad is it to drop the trans from below? I read some commentary on how, but how nasty is it? I don't have a lift, but I've dropped rear drive tranny's before with multiple jacks/stands. I'm a decent wrench, just never tore into front drivers before.
Add on...
