Been reading forums for I don't know how long... searched hours on end... and hands down, the archives house the majority of the useful info 3.0 swaps...
Here is the situation..
I have a 04 Taurus DOHC V6 motor (shortblock) I picked up for dirty cheap... 0 Miles on it.. still in the crate...
I still have a few questions...
Is there a different thickness head gasket to help with lowering the compression slightly? On a higher mileage motor I should replace the water pump and what else while the motor is out.
I was thinking about changing/checking the clutch, maybe installing an LSD (torsen or quaiffe ... which one??? )Any other tranny related issues/things I should check into???
If I am going to have to port the stock heads to work properly why stop with a minor port, but is a gasket match worth while? Or is time/money better spend on headers?
Last question, on the pistons is there a specific issue with the rings on this motor? Do I need to upgrade the rings while the motor is out if I plan on trying to eventually run boost?
I realize that the CR is not necessarily optimal for boost currently. However, I personally think it is easier to change heads than to change pistons on this motor.
I will not have a boosted motor overnight. But I plan to eventually run boost on this platform. I just don't want to have to redo things. Sorry for the long post, just trying to make the most out of my post and get answers while I have someone's attention... whatever little that maybe since I am not exactly a CEG regular...
Side note, for those wondering, this is going in a 98 ½ CSVT. Thanks for your time and responses..
