OutlawdSVT
Alright I have a good one for you guys. A friend of mine (me) has a 2000 SVT Tour and has the following issue:
The car shimmies really bad when accelerating from any gear but really noticeable at 3rd - 5th gear from 2800 RPM on up. When it starts to shimmy I can let off on the gas and the problem will go away, but as soon as I slowly accelerate the shaking will come back. It just seems that I (I mean he) has a miss of some sort, but definitely motor related.
I know for a fact that it isn’t wheels, tires, or spark plugs because I just changed them because of snow on the ground. The problem was there before and after these things were changed. This week I noticed that the issue was worse and that the car had a different sound to it and at the same time I had a check engine light and it said I had a misfire on cylinder 3. I pulled the spark plug wire as it was running and I did have spark from the coil pack, but the car didn’t change its pitch which I believe is not right. I inspected the engine bay more and I noticed that one of the injector wires at the harness was detached from the plug. I fixed that connection and instantly I could tell a difference in the way the car ran, but I still had the shaking as stated above. I have no CEL codes and I looked at all the spark plug wires and they seemed to be good. I looked and pulled on all my injector wires and they seemed fine.
When the first snow fell (which was preceeded by freezing rain) it took a while to get my (his) car started, it would just go click…..click, but eventually it did start w/ out moving any cables or anything. I then checked all my battery connections and they seemed fine. I checked my alternator and it puts out what it needs to. I’m still using my factory battery from 2000 when I bought the car. I have not done a load test w/ that yet.
Sorry if this is long, I tried to shorten it the best way I could.
Thanks for taking time to read this and hopefully someone has experienced the same thing so I can get this resolved for my friend wink wink.
Thanks
Thanks
