JoeM
Didn't find anything immediately by searching thus a quick post...
Doing my 3L build sooo
Question 1...
My 04 motor, came with a plate, blocking off the breather port between the heads. my old motor has the breather block, that bolts into the block on that spot... but doesnt come out without removing a head... The question is... do i HAVE to have this. If so, how i do i get it setup WITHOUT pulling the head to remove the old one, and to install it on the new motor. Let me know if you need a picture of the part im talking about... Ill hijack wombats pic...
Question 2... Since i am running a full 3L (heads,intakes, cams) Do i need to change the outside sprocket on the Crank or can i leave the one on the motor, that came with the motor.
That's it. I think I've got everything else figured out.
I decided to say screw it and im hijacking wombats pic and using a picture of mine.
1st pic is breather box in the middle... if you can get past the crazy lookin dude in the pic :laugh:
2nd pic is of the sprocket im talking about. youll see it on the crank...
Question 1...
