got a different question. I wanted to know if anyone can confirm that the gears/shafts from once transmission can directly be swapped to another, both are V6 mtx units.
one has a bad diff and the one with the good diff has a 3rd gear grind. thought is to take the gears/shafts from the one that is good and swap with the one that has the grind but a good diff. would the difference for the 2k+ units cause a problem?
