The AFR goes lean at tip in an enriches quickly as the RPM increases. It does PEG rich (10.0:1) when the boost hits so that needs to be addressed in the future as well.
Being that the stumble happens and clears so quickly its hard to get a good look at what the AFR did/is doing at that moment. I should data log the event and see if any of the PIDS are way out of wack at that instant.
It is not just at low RPM either. Even rolling in like 4th at ~3K and roll firmly into the throttle, the studder comes in. Basically, its comes somewhere between applying the additional peddal and reaching positive boost. So, in the lag region is where I feel it.
I imagine it would do the same in 3rd or 2nd but this thing tears through the revs in those gears.
