SVTCANUK
The new tie rod ends that I got have a narrower taper than the original ones. Because of this the tie rod slips through the hole easily but goes too far and I am unable to tighten the lock nut completely because I run out of threads and hit the actual tapered shaft. I checked the original ones and the taper starts at 13mm and increases, the new ones start at about 10mm and increase. Has anyone else experienced this? The part numbers I got are F7RZ-3A130-AA and MEOE-104, I cross referenced these on Motorcraft.com and they appear to be correct.
