SoopaCooga
Election Day is less than a month away, and I am due for an oil change, so let's practice polling by voting for your synthetic motor oil of choice for use in your force-fed Duratec.
To recap how people "voted" last time:
* Warmonger declares 5w30 good enough for even turbo owners
* DemonSVT stands by his use of 0w40 year-round
* A handful of knowledgeable folks vouch for 10w40.
* Various people suggest using the factory recommended 5w30 and 5w20
* Occasionally somebody gets the courage to ask, "Why not 20w50?"
To further assist you with being an informed voter, below is some Q&A with Mobil 1 and owners of performance vehicles:
Mobil1, I am the original owner of a 2004 Evo 2L turbo with 48,000 miles. I have been running Mobil 1 10W-30 all the way up to 40,000 miles. Then I switched to Mobil 1 Extended Performance 10W-30 just for the added protection. I change the oil every 2500 miles or less because I drive the car hard with a water/methanol assisted 30 psi boost. I have two questions:
1. Even though the owners [manual] and [factory service] manual strictly direct [owners] to use Mobil1 10W-30, would I be better off trying your new Mobil 1 15W-50 synthetic product since my car is highly modified? I drive the car in a very hot and humid climate and get a lifter tick at times.
2. Am I wasting money using the Extended Performance product since I change my oil every 2000 - 2500 miles, or am I getting some benefit with the Extended Performance over the Mobil 1 equivalent at these intervals too? --Steve
Steve, for your high performance application, we would recommend you use either Mobil 1 15W-50 or Mobil 1 Extended Performance 15W-50. The higher viscosity will provide better protection in conjunction with higher levels of anti-wear potentially needed with the turbo boost and severe operation and temperature. With your short change intervals, either product will still have adequate performance reserve remaining at oil drain. We need to mention that switching oils will cause you to give up some fuel economy, but we're assuming this may not be your highest priority. You may also want to switch back in the colder months to the 10W-30 for better low temperature flow and protection. --Mobil1
Mobil1, I have a supercharged 2001 BMW 330ci with 107,000 miles on it. It has always burned oil, even when new. Now, however, it burns a quart in only 650 miles. I was told I should have been using 15W-50 synthetic oil, but being in NJ, I was concerned that switching to a 15W-50 would be too thick for wintertime. Can I mix 0W-40 and 15W-50 in the winter for better protection, and use straight 15W-50 in the warmer months? The car is garaged year round, but sits outside at work during the day. --Alex
Alex, New Jersey has cold enough winters that we recommend you continue to use 0W-40 at least in the winter. In the spring, summer and fall you can use Mobil 1 15W-50 and see if this improves your oil consumption. If switching to the 15W-50 does not improve your oil consumption you may want to have your vehicle checked. You can also try Mobil 1 High Mileage 10W-40 all year round. --Mobil1
Mobil1, I am having thrust bearing failure in a 4.6L modified, performance engine. This is a street/strip engine. Many of my friends are having the same problem. I think it is the result of the removal of zinc from the oil. I was told by two, separate, racing-engine builders that the EPA ordered the removal of the zinc from over-the-counter motor oil. I use Mobil 1 5W-20. Is this true and do you think a zinc additive might help? --Randy
Randy, the active ingredient that you are talking about is phosphorus which is added through a compound called ZDDP. For products that meet the new ILSAC GF-4 specification, the phosphorus levels for the oil must be less than 800 ppm phosphorus. The ILSAC level for phosphorus has been reduced to protect the catalytic converter and other emission protection equipment. The engine manufacturers are confident that this level of phosphorus will protect both new and older engines. However, there are Mobil 1 products which have a higher level of phosphorus (phos) and can be used in engines in racing or high performance applications: 0w40, 5w50, and 15w50. --Mobil1
