RacerJason
So, I failed my 1st smog/e-test with a bad o2 at idle reading. Pulled the codes at a shop and went about replacing the DPFE sensor and the EVR solenoid. That eliminated my check engine light (for the first time in the history of 4.5 years of ownership!). I re-tested yesterday afternoon and BAM... failed again(CO and HC ppm figures below). The e-tester says it's either an o2 sensor or the TPS. Thoughts? My 10-day temp sticker expired today too! Should I gamble on it being the TPS, replace it and re-test?!?!? I have no CEL so I'm guessing there are no more codes to yank right? Thank you!
(@ Idle) Pass Reading (Failed)
CO 0.70 4.41
HC ppm 150 401
CO 0.70 4.41
HC ppm 150 401
