KAOS_3.0
You are a tiny bit right here, but you have gone completely the wrong direction with it. EGR isn't about making power at all. EGR is used to re-introduce exhaust gases into the intake tract. Exhaust gases are essentially inert as far as the combustion process goes, so it replaces some of the oxygen in the incoming air charge, allowing less fuel to be injected and maintain a given air/fuel ratio. This improves fuel economy, and reduces the temperatures in the combustion chamber which also reduces NOx emissions. Because of the drop in temperature, ignition timing can be advanced a bit more to partially compensate for the lost power by the reduced fuel/air mixture quantity being burned. EGR is ONLY used under part throttle conditions to improve fuel economy, and reduce NOx emissions. EVERY calibration I have ever looked at, turns off EGR completely at WOT.
Again, a little bit of right, but you ran off into left field with it . . . First, I agree that PCV system can be a source of crud in the intake. Second, I agree that PCV helps with acidity of the oil by removing water vapor in the crankcase. But, as Pud pointed out, there are other very good reasons for the PCV system, not least of which is reducing windage in the crankcase, which has proven to reduce drag on the rotational parts, and consequently improve power by a small but measurable amount. As far as dumping into the intake, there isn't really another readily available way to draw a vacuum on the system without installing a secondary vacuum pump (which has been done in a number of applications before). A good way of managing the "crude" is to put an inline filter/trap into the PCV line. And lastly, the volume of air coming through the PCV is very very small compared to the volume of fresh air coming in, especially at WOT, so I wouldn't worry too much about any vapor coming through there, besides, the water vapor provides additional mass that expands from the heat of combustion, lending a bit of help in pushing the piston down.
As for the EVAP, I've never looked really closely, but I'm pretty sure the majority of engine calibrations turn it off at WOT also, so the power concerns are basically pointless.
agreed at all points there.
evap has an interval based on how long the fuel vapor has been stored in the charcoal canister, and is then injected at the next time the air fuel ratio can handle it. I seriously thought about deleting my evap system, but ultimately it seemed like too much trouble to remove all that crap.
[edit]
also thought I'd throw this out there since we're talking about deleting EGR and such, and to help get this thread back on topic a little.
if you want to delete the EGR, you can run the st220 intake manifold, since it's probably one of the very best available for the 3l.
actually, you could even use it if you didn't want to delete the EGR, but it would require some modding
