Chris@CTA
Has anyone used this product before? I want to use this product on my Vortech'd 2.5l 1998 Contour SVT. The software appears to be fairly straight forward to use, but my reservation is that, not having too much experience with doing an initial tune, how should I set the offsets for the timing and fuel. The Vortech kit is installed as per the Vortech instructions, and yes, still using a FMU, only addition is Buckshot's aftercooler. Sniper's tech support says that it will do a safe initial tune, as long as you input the correct engine data, etc.
High RPM Fuel Modifier (AFR) + to Lean / - to Richen
Low RPM Spark Modifier (Deg)
Med RPM Spark Modifier (Deg)
High RPM Spark Modifier (Deg)
Global Spark Modifier (Deg)
Global Fuel Modifier PT + to Lean / - to Richen
Global Fuel Modifier FT + to Lean / - to Richen
Any ideas?
Thanks.
Fine Tuning
Mid RPM Fuel Modifier (AFR) + to Lean / - to Richen Low RPM Fuel Modifier (AFR) + to Lean / - to Richen
Any ideas?
Thanks.
