So I'm driving home on the freeway, going about 70 in 5th gear when the motor stumbles and clearly wants to die. I pull over to the emergency lane and it dies and will not start...no clanking, ticking or mechanical sounds accompanied the problem. I end up getting a AAA tow home.
I fuss with it a couple of nights after work and get nowhere...everything checks out perfect from fuel pressure, to spark to Crank sensor, etc...I check cranking vacuum..NONE. I check compression...rear bank 180...front bank NONE. I think: "Oh, I must have washed out the cylinder walls with all that cranking". Added oil to cylinders, check compression..NONE. Pull UIM...look in LIM....yukky loose carbon flakes?! Pull valve cover....Exhaust valves look to be in a somewhat down positions and rockers are laying around on their sides. Intake side looks good from up top.
Best guess is my exhaust cam timing got retarded a bunch very quickly. The only thing I can think of is that the chain jumped a few teeth.....what's weird though is that the front sprocket marks are the same number of links apart (11) as they should be, everything else is wrong.
Here's a pic of the backside of the cam sprockets at the pulley indicated TDC:
Any epiphanies? Anyone?
It was not this way 2500 miles before when I assembled it. It's been an absolute dream until that moment.
I do know I'm removing the timing system and checking and that at least one head is coming off, what I don't know is WHY???
Of course I've put myself at risk by installing an SVT Cam on a Taurus head, but it turns well and the entire timing set is brand new and seems tight...
I'll keep you posted as I discover what's up
