milleniahead
Ok for the past 2 and half weeks ive busted a leak on my radiator hose (due to it sitting on the battery harness so it just rubbed itself a hole).. What i did was tape up the hole with duct tape and kept changing it until i could get a new part.. (i kept puttin in dexcool mixed with water whenever it got low) But of course the day when the part comes in the car finally started to overheat.. it never reached the H, but got about a quarter of the way to it.. I stopped right away put in more coolant/water. I then let it sit for 30min and then drove to my friends house to put the part in.. Everything was in, everything was good..
Now about 3hrs later i noticed the bastard was still leaking.. I threw in more coolant and let it sit overnight. Next day was almost empty, so in goes more coolant. I get to work, look under the car and its still leaking.. Didnt know where the fk it was comin from.. So at lunch i drove around for awhile then stopped and popped the hood and watched where it would come from. What happens is the coolant bubbles out of the overfill hose and leaks down onto the ground just before the radiator fan comes on, when it comes on, it goes down again..
What my guesses were is that maybe i was just using too much water with the coolant which overheats and bubbles up etc. Or maybe the thermostat but it doesnt run hot/cold it stays in the middle...
Now my friend says it could be the head gasket which ed up the cyclinder heads etc when it was overheating..which will make me need a engine/rebuild basically.. he said the gasket could cause air into the system which forces the coolant out the overfill hose.
is that tru? am i going to need a new engine? it runs fine but when it sits, it will start to bubble over and out the overfill hose and go back down again when the radiator kicks in. Is it too much water? head gaslet? cyclinder head? thermostat?
lastly if so, should i go with a 3L or just get another svt engine.. Me and my friends can install the engine but i just want to know what route i should take. I kno i can get a 3L for 4 or 5 hundred but what else comes with a 3L install? Would i need to do anymore upgrades to the tranny etc? I would read more into it but im at work and im not supposed to be surfing like that.. and if i did get another svt engine, who the hell has them?
