Ok, so I've said it before on the old forums and I confirmed it again last night. There is NO need at all to cut the tabs on the bulbs to get a 9005 into a 9006 socket. Wiggle it around, drop a couple tabs in first, rotate, then the other will slip in. I don't know why everyone is cutting. :shrug:
not talking about getting the light bulb into the light, the harness is keyed for the lights, you need to modify the light or the harness to swap the lights ... your right with alittle wiggling around you can get the high beam bulbs in the low beam location
so no one has had any problems with melting? I want to do this too, but havent had my low beams go out yet. NO issues with blinding other drivers either? I know you could adjust them if the were too high, but just thinking you wouldnt eant to end up with some really bright fog lights.
