z06killinsbf
A little history: I bought my 98' CSVT about 3 months ago. The prev owner said the compressor needed changing since the a/c didn't work (and hadn't for a few years). I did some troubleshooting and sure enough the compressor was bad. I replaced the compressor with a reman on Saturday, got it charged and tested that day. It worked like a champ for two solid days. I got in it early Tuesday morning and it had stopped working. Today I tried filling it up with alittle leak tester to see where it was leaking. You can hear it pissing the pressure out (somewhere in the vicinity of the compressor) but there is no oil nor leak detector anywhere. I thought I had maybe installed the hose block incorrectly but when I undid it, the bright green oil was then and only then visible. I sealed it back up, torqued to spec and tried refilling. Still the out rush of pressure can be heard. AM I missing something or did I do something incorrectly? I needs me some a/c as it is 100 deg outside with probably 60% humidity, it HOT.
