my98SVTturbo
are there any polyurathane motor mounts out there to upgrade my SVTs? and alos whos sells them if there are?
and Josh (pole120) sells his solid polyurathane ones.
Note that if you want the regular "feel", you should stick to OEM parts. The "Polyurethanes" have been reported to give a little more vibration. Better performance but harsher ride.are there any polyurathane motor mounts out there to upgrade my SVTs? and alos whos sells them if there are?
For me, I found the 94A poly filled rear roll resister is a little bit too harsh. I got console/instrument cluster rattle when the RPM is between 3000 - 3200 RPM. It's really loud.
It's your stearing column covers rattling agains eachothr, tighten them up or addsome foam rubber under each one and all will be well. I've experienced this on several cars including my own, all is quiet now. Give it a shot.
~Josh
Thanks both Josh and Tony. I think I am gonna try that first.
Tony, any chance you have some pictures that we can follow?
Thanks
~Rick
