watcanbrowndo4u8
So I ended up going to Logan Motorsports to get a tune and they were working on itt but then quickly found problems.
Under load they found it was misfiring after 3500 when the secondaries open up. Once that happens they saw that the timing starts bouncing around all over the place. The fuel pressure is 55-60lbs is that high? I checked the front 3 plugs and one wire wasn't seated properly but that didnt help.
I will be checking the back three plugs and wires sometime after this long weekend, The only other suggestion they had was a bad fuel rail pressure sensor but idk.
I was wondering if you guys had any ideas. The vacuum readings were fine, if you guys want more info just ask.
THANKS!
THANKS!
