Big Jim
There is a theme developing over at www.bobistheoilguy.com that I thought would be worth sharing. It has developed into several extremely long threads so I'll just pass on a summery. These threads are a little like the "everlasting" thread we had here about RedLine MTL, except that it expands much more rapidly. In less than a week, one of the threads is in the range of the entire "Watch Out" thread on MTL which went over several months.
Mobil took Castrol to task a few years back on the definiation of synthetic oil. Castrol Syntec used mostly group III base stocks which many considered to be an enhanced petroleum product rather than "pure" synthetic. The "pure" synthetic" term was reserved for group iV and V basestocks. Mobil lost. Since then Mobil has still posterized itself as better because of using mostly group IV and some group V in their blend for Mobil 1.
Recently someone on bobistheoilguy ran a gas chromatagraph test on two of the many products that have the Mobil 1 label (15W40 for one) and found that they included a significant quantity of group III in the blend.
No other gas chromatagraph tests have been performed.
Mobil's responses have been evasive.
Feelings have run amouk as opinions about the significance of this have been expressed. Some say that they will never use Mobil 1 again. Others say that if they have found a better way then fine, as long as the product performs as well or better than it has in the past. Still others are upset that there may be significant cost savings that Mobil is not passing on (just like Castrol has never passed on the cost savings for their methods).
It is unknow if this was a temporary measure to overcome the shortages in basestocks caused by Katrina and Rita. It is also unknown if this involves other viscosities or just the two tested.
Most interesting of all is how wild the accusations and heated the discussion when there is really so little really known at this point.
