Darkcrimedc
- Joined
- Nov 1, 2007
- Messages
- 91
Purchased the car last august. Battery light would flash every once in a while in high rpm's only. In March, my Alt died along with the battery. I had a friend replace the alt (Ford Reman.). Everything worked fine until my battery light came on again after I raced someone. It would come on at high rpm and low rpm's only when the car was moving though, not when I was in neutral and revving.
I took my car into a shop to have them look at my ac, (ended up replacing a tie-rod while they were at it), and while they were doing that, I had them check my alternator.
The mechanic said my alternator is bad (decharging itself). Within the 100ft trip home, my lights started to come in (brake light, abs light, etc, same thing that happened the first time it died). I went to start the car the next day, Nothing. Batteries dead.
Since then, I replaced the Mega Fuse, and had my warrantied battery retested and recharged. I installed the battery, car started, checked my voltage and I was only reading 11v while the car was running (ok, bad alt again). That was the only time I started the car (a whole whopping 5 minutes).
I just went out to move it to my driveway, and the car won't start (clicking, beeping sound of my door open is getting weaker), looks like my battery drained again... What's going on here? shouldn't the full battery have lasted more than a few minutes of running before it drained itself? This car is killing me. I haven't kicked the car yet, I'm about to!!! hehe.
What else could it be? just a bad alt again? anything else I can do? I read up on the clipping the wire deal on the alternator to the battery (would the dealership cover this?), but would that keep killing the alt/bat?
Thanks for any help.
