EuroTour
Does anyone know if these will fit without rubbing? I know they'll be tall but they would be better for the snow.
They will not fit at all. You will not be able to get the wheel anywhere near the hub.
One of times I bought tires, the tire guy misunderstood and tried to mount up 225/60R16 instead of 225/50R16 and they hit the struts before the wheel could match up to the hub. The diameter is just way too big. The 205 is the same diameter as the 225.
Forgetaboutit
The extra width was not nearly enough to have made a difference. Look at your struts. The 60 series tire will hit above the spring perch. You would need to move the strut about 3" or so for a tire of that diameter to fit in the space given.
Nope, it was 215/50R16
They might fit. It'll be close, but people have run ODs that big on blingin' stunna wheels so you might get away with it.
You don't want them anyway, though. For snows (on 16" rims) I'd go with 205/55r16, or narrower if you can find it. Taller doesn't really help. Better yet would be 15" wheels, just so you don't crud up your nice SVT wheels.
Word I run 195/65R15's in the snow :shocked:Better yet would be 15" wheels, just so you don't crud up your nice SVT wheels.
I disagree.
Don't forget that the sidewall height is relative to section width. That is, 60% of 225 is greater than 60% of 205.
Here's the numbers:
225/50-16, notional radius is 12.4"
225/60-16, notional radius is 13.3"
205/60-16, notional radius is only 12.8" Might be an issue, but not nearly so definite as with the 225/60.
215/55-16, notional radius is 12.7" (Wasn't that the stock size on the 98? :shrug: )
Stock size on the 98 was 205/55ZR16. Stock size on 99 and 00 was 215/50ZR16.
I'm basing my comments on what I saw at the tire shop when they mistakenly tried to install 225/60ZR16 tires. They hit the spring perch on the struts.
