realslimshaver
New CEG'er
hi all... i am now a former contour owner and i was wondering if someone could help me...I sold my 95 contour back in June and now drive a 2002 VW Jetta TDI. i am interested in how the DRL system worked in the contour... i believe that the high beams were run in series when used as daytime running lights. Then in parallel when used as high beams... I am interested in converting my lights in my Jetta to do the same thing... the Jetta uses a Duel filament low and high beam bulb(9007), and as it is now the DLRs are just the low beams on with out any running lights... so this means that i go threw the low beam part of the headlight fast yet the high beam gets nearly unused.
I assume that this is accomplished threw some sort of relay or series of relays but I gave my haynes and my ford cd to the person I sold the car to. Does anyone have wiring diagrams for the headlights that they could post up or give me a link to? Or does any more info about how it works.
Thank you
Thank you
