Hi Gang,
Having a charging problem and wanted to get some advice.
99 SVT Contour.
Battery Charging light on steady. Replaced the battery and replaced the alternator with brand new ones. Checked the Mega Fuse and it tests good.
Car will start with the battery charged but eventually will die after 15 minutes as I am not getting 14v to the battery.
The F5 15Amp fog light fuse is GOOD and voltage is measuring across the top of the fuse, but the Fog Lights DO NOT work.
My next thought is the fog light relay to get the lights working but I am curious if this relay being bad would also affect the charging system?
I have looked at the wiring diagrams and it looks like a logical next step to replace the fog light relay. BTW where might this relay be? I found a white relay attached to the wiring harness just downline from the light switch behind the dash.
Thanks Gang,
Any input would help.
Bob
99 SVT Contour.
Thanks Gang,
Bob
