Damien
I had a system for a good long while. all was well. I traded in the old pioneer headunit for a newer one (with a USB port). After hooking up the new cd player, it would not power on. There was no power from the constant power wire. Circuit City ended up patching fused lines from the ignition circuit and it worked. Problem is that now it makes horrible noises. Even if the car is not running there is interference noise in the subs... like a rumbling. if I turn the volume all the way down, right when I go from 1 to 0 it pops. If I hit my brakes it pops, same if I turn on the headlights... anything I do that uses power will make a noise through the speakers... subs and the components. It's making me crazy. Any ideas? how can I check to see what is going on?
