Brent372
Official SE Event Coordinator
Would it be possible to make a tune for the SVT motor that will allow the use of 87 octane without any side effects or long term damage?
its certainly possible (just a spark timing reduction ought to do it.)
but your going to need to spent at least a few hundred for the chip and more for the tune. so its probably not worth it.
IDK if that would work or not but it is however a good questionThis is more of a question than an answer but could you get a PCM out of a nonSVT 2.5l car? It probably won't work because of the knock sensor and the compression difference. Perhaps someone out there knows.
