95Mike
Hey guys. 2003 taurus 3l with 25k on it and new clevite rod bearings. I did the no-fuel/no spark priming the first time I fired it up. Then I let it run for 40 minutes in neutral at 2500-3000 rpms with a brick on the gas pedal. Then I ran a can of berryman's b-12 through the intake vacuum ports and changed the oil and filter. Now I have ~450 miles on it after that and it runs great. No leaking fluids or anything other than perfect.
My question: Is it safe to switch to Mobile 1 full synthetic yet? I've searched with mixed results. Some say to run more miles, some say to go to part synthetic at this point. Some say it should be fine. Any input? My piston rings were untouched (I did not take off the heads) so they should be of no concern. Same with main bearings.
