aircougar
After replacing the Coolant sending switch, and the temperature sensor that are both located on the water Crossover pipe between the heads...I still do not have a working Coolant temp gauge!!
I even jumped the temp sender switch with a wire from the sender to the white/red wire after the harness connector next to the driver side strut tower... and still nothing.
I figured something may have happened to the connector/wiring when I put the newer motor into the CSVT, but I still can't trace down the problem.
I checked the fuses before, but I would figure that I would lose all of the gauge cluster if the fuse went out...
I need some suggestions...anything that you have run into that is similar to this will help me out, thanks!!
