iskoos
Hi guys,
I am fairly new to this forum but NOt new to world of Contours. I have owned one for 9 years. It is 95 Contour GL 2.0L 4cyl Automatic.
I am having a strange symptoms recently. All of a sudden my car started showing weak(low), erratic, sputtering idles.
This issue started all of a sudden. When car comes to a stop, idle becomes very unstable and if the engine is not warm, it will most likely die. When I see the idle gets erratic(I cannot tell the rpm; I don't have tach), I pump the accelerator couple of times and this helps.
When you accelerate, and/or when you drive at any criuse speed, the car is smooth and reliable. There is absolutely no signs of any problem.
The problem is only at idle.
When I start up the car in the mornings for example, it starts up and idles for couple seconds and then it sputters and dies because engine is cold. I need to keep the gas pedal depressed for a few seconds for the engine to warm up so it can hold the idle but even then idle is very unreliable...
What I did so far:
1. I started with cleaning the oil separator and changing the PCv valve thinking that PCV was clogged. The PCV was dirty but it wasn't clogged. I replaced it but it didn't help.
2. I removed and replaced the IAC valve thinking that it was the culprit and I was so sure of it. I was WRONG!.. It wasn't the problem either. I chekced the IAC valve and the original one was working but didn't want to take a chance and dropped in the new one just to make sure. Nothing changed unfortunately... So I know it is NOT IAC valve...
After driving and testing the car for couple of days, I decided to clean and put the original IAC valve back so I can return the new one since it wasn't going to help. I did it yesterady and when I put everything back and cranked the car up, It fired up immediately. I drove it, it was driving fine but all of a sudden check engine light came On and stayed on all the time. I opened the hood to realize that I forgot to plug back the MAF sensor connector!..
I did put it back and the idle became erratic immediately.
I unplugged it, it worked fine; put it back again; having the same issues.
I am really confused!.. This morning, I started the car with MAF sensor unplugged. It started fine, the idle was a bit high at first then it slowed down. I drove the car in the neighborhood for 5 minutes. it drove fine. But the CEL on all the time and when I stop I realized that idle was still a bit high. I guess due to MAF sensor being unplugged.
I had codes 181 and 157 when I unplugged the MAF sensor and I guess this is normal. I already had code 335 in the system before I unplugged the MAF. Code 335 (My car is OBD-I) is about DPFE sensor but I replaced that just two months ago. So I doubt that is my problem here...
So right now I am puzzled and asking you. Does a bad MAF sensor cause rough, sputtering erratic idles???
Thanks in advance...
What I did so far:
