todras
Pretty fly for a white guy *cowbell*
Finally found one that wasn't beat to crap. So much better than the POS 96+ one that just lies there like a dead hooker.
What did your 96 one look like? I have a 95 but the backing is not the same, it is just yellow foam where as the 95 you have looks like it has a no slip backing?
if anybodiy else has a problem with the wood warping all ya have to do is mist it down with water and weight it gown flat when it dries it will be flat again.
if anybodiy else has a problem with the wood warping all ya have to do is mist it down with water and weight it gown flat when it dries it will be flat again. also is it just mine or does the thing that secures the tire in seem to interfere with the liner laying all the way down in anybody elses car let me know chad
What do you mean lying all the way down? When you put the white cone in the hole in the board and screw it down, the thin rim of the cone should be up against the board and the screw should be recessed into the cone... Is that what you mean? :shrug:
he is talking about the post 98 style trunk carpet that has some think wood/carboard like material in the carpet that is over the spare tire. when it gets wet it deforms and caves into the spare tire well.
again the pre98s have the seperate fiber board and carpet like you have...
I think its time you come to a meet and check out the differences between a pre and post 98 ....
Im probably coming to the July meet, sheesh :laugh:
Your brining the SeVT right, that is post98?
I have been to a junkyard and seen post98's, I guess I never notice anything though :troutslap:
