I've spent the past 2 weeks searching and reading about my problem. I have not seen my problem mentioned. I have no symptoms other than O/D light flashing. There is no bucking, speedometer is not erratic, no hard shifting (except after O/D flashing), no slipping out of any gear, no problems shifting between gears, drained/refilled ATX fluid 3 times over few days, I have tried to pull CEL code using my Harbor Freight CAN/OBDII scanner but came up empty of ATX codes. Doesn't seem to match symptoms of the several sensors that seem to commonly go bad.Only emissions related codes that's been there for a few years contstantly.
May be a coincidence, but I washed the engine bay before this problem started. Don't remember if it's immediately after or several days. No power spray, just Simple Green and the "mist" setting on the sprayer. What is the grounding bolt on the transaxle someone mentioned that can cause electrical problems? While I was draining the ATX fluid I did notice a bolt with a wire on the passenger side of the tranny but the clip for the bolt was broken.
Any ideas?
Any ideas?
