95pgt-t
first off,i've read all the threads i could find under surge,or surging.
i've changed the plug wires twice w/known working wires,and once w/brand new. changed the plugs and gapped them,changed and cleaned the maf twice w/working maf's,new fuel filter,cleaned the egr,iac and upper and lower manifolds,swapped tps'...basically i've done everything i can think of,short of changing the coil and fuel pump.
by changing those parts all i did was move the surge from 2750 to 3400:shrug: i'm getting no codes,and have no pending codes:shrug:
basically it runs smooth under wot in any gear at any rpm, at any load. but if i'm accelerating at partial throttle,say less than 50% it surges or bucks at 3400~ and than again around 4k(only if i stay at that constant light throttle)if it bucks at 3400 and i put the pedal down,it's smooth again:shrug: i'm at my wit's end.
btw,its a early 99 svt
