novellino21
Yeah...no. Not a fan of those 18's at all.
Booooo!!!!!
I like the FSVTs. Of course, I'm biased as I have a set. I believe that every retailer I have ever seen lists them at 21 lbs, which would make sense because E1s are like 20-21 lbs with thick spokes and FSVTs are an inch bigger with thin spokes. Then, accounting for the fact that you are running less tire volume overall, the whole wheel/tire combo should weigh less or the same at worst case scenario. The first ones remind me of ST200's which I don't care for at all. I'd stay stick with the FSVTs and get a decent set of tires. Either set would look better if your car was lowered.
Check your PMs .
Aaron
even as common as FSVT wheels are, i think they look better then the 17's pictured in #1
You're usually pretty good with info. but c'mon a 17x7 that is 25#?i'm gonna go out on the limb and say that bat inc is wrong:shrug: the stockers are about 20-21lbs. five spoke svtf have to be pushing 25lbs or so.
it does look better on a lowered car.
definitely monza's. FSVT's are ok, but certainly not unique and to be honest, kinda played out.
I vote for these.
