Thinking of using this in the new trans I just put in my 98 SVT Anyone else tried this?
http://www.bmracing.com/index.php?id=products&sid=4&cat=11&subcat=&pid=103
Latest Synthetic Fluid Technology
Excellent companion sale for all B&M transmission Kits
Mixes with other types of Automatic Transmission Fluids
Formulated for late model vehicles
Suitable for Racing, Street Performance,
Towing and Off-Road
Cool Blue Color
Easy pour quart bottles
Meets or exceeds Mercon or Dexron III requirements.
B&M’s Synthetic Trick Shift is formulated as a performance automatic transmission fluid. B&M’s Synthetic Trick Shift features the latest synthetic fluid technology suitable for most late model automatic transmissions as well as many manual transmissions. Not an additive, this safe and effective formula of extreme pressure agents, foam inhibitors and exceptional thermal stability will provide a long service life for your transmission. Ideal for street use and high performance applications including racing, off-road, towing and heavy- duty fleet use. Synthetic Trick Shift may be mixed with all other types of ATF but works best by itself. When using B&M Synthetic Trick Shift you can literally ‘Pour In Performance’. Meets or exceeds Mercon or Dexron III requirements. Not recommended for automatic transmissions manufactured after 2000. Synthetic Trick Shift is not intended for use in CVTs. May be used in manual transmissions requiring automatic transmission fluid as lubricant.
Towing and Off-Road
Cool Blue Color
