svttouruofl
Well the clutch went out the other day in my svt and I went ahead and tore into the removal process. As of yesterday I dropped the entire subframe with the engine, trans, rack, and entire front suspension still attached to it and just lifted the body off. The current mods/maintenance that I plan on at the moment are:
-Stage 3 clutch
-improved shift forks
-fix my bad 3rd gear synchro
-install at least the stronger pre98 differential if not a torsion or quaife
-MSDS headers
-Aftermarket Y-pipe
-Have the Alternator rebuilt or replaced
Is there anything else that I should do while I have all this out, or not do that I'm planning on doing? A few people have told me to at least check the timing chains, and go with a DMD pulley. A few others have also told me to pull and clean the UIM and LIM while at it. What are your feelings on this situation and what would you do. I'm going to keep it at the 2.5 at the moment and build the trans now to take the upgraded power and abuse that will come later.
Also on the headers I have been reading up on where the coatings have been coming off after about a year and people are stripping them and just using high temp paint. Should I just order them bare and use the proper high temp paint to begin with?
-Stage 3 clutch
-MSDS headers
-Aftermarket Y-pipe
