Yah, I tried the dawn and scrub brush after I let the oil dry sit on it for about 15 minutes, and it is stained pretty bad..... This is how the story went:
Oil change monday night at 6pm. Went great, guys were nice, and it is the only place I have ever gotten my oil changed at since I owned this car (8 years).
Drove home 7 miles. Parked it in the driveway to take my engine bay pics that I just posted. Car sat in that spot in the driveway for 2 hrs then I moved it in the garage. No oil spots in the driveway.
Wake up to go to work the next morning (tuesday). Start the car up and immediatly hear "gurgling". Ran it for about 4-6 seconds. Turned it off. All the oil squirted out from the filter :shrug: WTF?
I called the lube place and they were at my house within 20 minutes. Jacked the car up, installed new filter and filled with oil. Started it up and checked for leaks. Everythin is tight and no leaks. COOL.
He leaves and I decide I want to clean up the mess in the garage because apparently he wasn't going to do it. I start it up, no "gurgling", good, back up enough that now my car is halfway out the garage. It starts gurgling again! ****!
I pulled it off into the grass so I didn't track the oil on the new driveway more than it already has. Called up the lube place and talked to the owner.
He says "bla bla I've been doing this for 13 years bla bla your wire harness is bad or something bla bla bla tow it somewhere and have them look at it bla bla bla I will come out one more time to put another filter on and fill it again bla bla".
I said "ok"
He was going up and down about how it is not the filter and what do you know..... the 3rd filter is good :shrug:.
No leaks, smoking car, and 3 oil changes later I am back on the road to the lube place for free carwashes to clean the oil off the car......
I think it was their cheap ass filters. What do you guys think?
BTW, no motor damage because I am smart enough to shut it down when something is wrong.... they are lucky I did that.
I think I am going to give the car away, because it is just bad news for me. I am kind of worried to go and start it this morning . I will let you all know what happens...... wish me luck :crossfingers:
Good to hear that you were shutting the engine down instead of letting it run...... Weird that 2 oil filters had issues... did they not get them tight enough.. or leave the old rings on..... Joe... this is why I do my own oil changes, yes it takes some time... but at least I know it's done right then....
You could always give your car to me.... I'll take care of her
