Hello,
Car: 1999 Contour, 4-Cylinder, 162k miles. I have received so many conflicting opinions about my problem from laymen and mechanics. I need help.
About three weeks ago CEL P0171 (System too lean, bank one) came on. The car wasn't running perfectly, but until that light came on I assumed age was the cause.
Someone suggested cleaning the MAF sensor with spray so I did. A few days went by and nothing changed, and I was told to try the PCV valves, the upper O2 sensor, the lower O2 sensor, the fuel system, and that "it's probably a huge problem and we'll need all day to look at it." That was a shop owner.
I was eventually persuaded to replace the lower O2 sensor first. I bought one from Autozone, but I couldn't get the lower one off as it seemed to be screwed in, somehow. At that point I found CEG, where I learned through searches I should replace the upper. I went to return the lower and Autozone insisted they sold me the upper. So I went back to replace the upper but the plugs didn't fit. The O2 sensor from Autozone had a round plug and the O2 sensor on my Contour had a D-shaped plug. I went back to Autozone again, but their computer did say they had sold me the upper sensor for a 1999 4-Cylinder Contour. He didn't know what else it would be. But it doesn't fit!
About a week and a half ago, the engine started loping after a few minutes of driving, but only when the car is stopped. Above 5-10 MPH there is no problem, or at least it is no longer noticeable. It happens 60-80 times per minute. It happens quicker when the car has been driven recently (heat?) Sometimes it is strong enough that the "troughs" cause the car to die. I have no problem instantly restarting it.
1. Should I replace the O2 sensor, and if so, how do I get the right part from Autozone?
2. What else should I try replacing?
3. What do I risk damaging by not addressing this problem really quickly? I don't have much money and don't know a trusty mechanic, but if I am out of time I guess I will bite the bullet.
4. Is this really obvious?
Here is a link to some pictures. I hope they will speak clearly where I was unclear. They are about 500k each in size.
http://www.flickr.com/photos/25741071@N04/sets/72157604782109298/detail/
