allen78j20
New CEG'er
- Joined
- Apr 27, 2008
- Messages
- 6
Hello! I have a 1997 Mystique , Zetec engine automatic with 145.xxx miles on it. My son bought it a month ago and it was running fine. We were checking the plugs and we found that the vally was full of oil. He and a friend replaced the gasket but when they removed the plugs, oil ran down into the cylinders. The car ran and on his way home started to stall on him. He finally got it home. Now it wont start. I bought a book for the car, I do that with every vehicle we have owned(good habit)and here is what I have so far:
Engine rotates but wont start, I took off the camsprocket cover to make sure it was rotating.
Check Engine light goes out when trying to start.
Checked the fuel filter and it was clogged, and I replaced it.
Checked the coil pack, primary and secondary windings within spec.
Replaced the spark plugs and wires.
Checked to make sure fuel was getting to the fuel rail by pushing on the fuel pressure release valve(schrader valve) and there is plenty, took 5 seconds for it to fully release pressure.
Checked the fuel cutoff switch to see if it was popped up, and it wasnt.
Checked the fuel injectors to make there they ohm'd out, and they are within spec.
Tried to start it in Park and in Neutral, same thing.
I havent pulled the timing covers off to check if the timing was on, i.e no 1 on tdc, just incase it might have skipped a tooth or something. Im trying to save that for last!
Im at a loss!! Hopefully someone can point me in the right direction!
Any help is greatly appreciated! Thanks!
Allen
Allen
