Beans
Addicted CEG'er
hmmmm..
Jb weld.
Lots of it.
:laugh:
Jb weld.
Lots of it.
:laugh:
I actually disagree with those who say rust played a part. Reason being is that the front, inside area of the strut tower completely SEVERED, which is NOT normal for most metals (what is the exact composition of the frame/body anyways? steel?). Even if the back side on the outside by the trunk was rusted as you say, that doesn't justify how the front just ripped apart like that. I think there was some sort of other previous structural damage, which was why I asked if there had been an improperly placed strut tower brace...
It looks like the rusted area created a pivot point for the rest of the tower to twist and shear off.:shrug:
It looks like the outer top rear corner of the strut tower broke while under pressure -- possibly due to corrosion -- and tore the front inner corner and side.
Close-up of the corroded break:
http://i211.photobucket.com/albums/bb242/qbshurafa/4-20-08RearPassengerInstall016.jpg
The area is clearly corroded and you can see the rust run-off from it in this image:
http://i211.photobucket.com/albums/bb242/qbshurafa/4-20-08RearPassengerInstall017.jpg
The other side is clean:
http://i211.photobucket.com/albums/bb242/qbshurafa/4-20-08RearPassengerInstall018.jpg
Because the front tear has no corrosion vs the rear with lots of corrosion, it seems that the corrosion was present before the damage as opposed to being a result of it.
I don't want to sit here and argue, but it is very obvious that the damage had to have started toward the front of the tower. It is severing FROM FRONT TO BACK. So how could it start in the back and sever from front to back? It makes no sense.
That makes absolutely no sense. I took a good long look (being an engineer), and I have deduced the cracks started right in the middle, where the three cracks meet. This is why I asked, again, if a strut tower bar was improperly placed. I think they started here, and have slowly creeped around the tower. Think what you want, but I think it started here:
zorrex, but if you think the metal teared "slowly creeped around the tower," wouldn't there be some rust on the surface of the exposed steel? Know what I mean?:shrug:
Yes I do, but water wouldn't come around the whole side of the tower. It would only be in the ridges, as can be seen on the back outside. There also appears to be some on the front inside...
I don't think it really matters how the tear happened.
I highly disagree. If it can be determined that the failure was a direct result of a bad casting, then I think a case could be made against Ford on this. If it was a result of rust, then nothing can be done...
