CSVT#49
Addicted CEG'er
This is going to be long, but I want to be thorough.
Ok well I've been having a lot of problems shifting gears. I thought it was an issue with my cable end adjustment. I adjusted them and... well my shifting was OK. Then I started missing 3rd gear and occasionally 5th gear just as I had before. I was getting pissed. Well today I finally tore into it a little more. I took the boot off the shifter and looked at the ends. No issues. I looked at the cable ends... again no problems. I took off the dust cap for the Focus shift tower... still nothing out of the ordinary. I got in the car and started slamming the shifter around to see if I could get it to act up without the car running. Boom...
The shifter was STUCK in 5th gear. I was like WTF?!
Got out looked at the shift tower tried moving the hammer around for the forward and back motion and it moved back into neutral... checked the cable ends again still nothing that caught my eye. So I decided to see if I could get it stuck again. A few more shifts and.. yup stuck back in 5th.
Got out again and wal la.
The shift tower... when the hammer moves back and forth it pulls on a pin which rotates the tower. The pin also slides up and down in the slot on the tower to allow the shifting of the other cable which moves the tower up and down via the lever closest to the bell housing. Well... this pin I described looks like it sheared??? So when I shifted into 5th gear the now sheared (or so it looks) pin came out of the slot on the tower as it was lifted up from the other cable. This caused the tower to bind, preventing it from rotating back and also moving back down with the other cable.
Has anyone seen this before??? I'll post pics soon.
