greasemonkey1489
I recently put a used motor in my 1995 Contour SE 2.5L. The main wiring harness was frayed and I was able to find a brand new one on ebay. I have the MTX-75 tranny however the liquidator failed to mention that the harness was for an automatic. I studied wiring schematics and decided that the harness should work fine. I was able to splice in a park neutral safety switch for the MTX. The engine starts and runs but it surges at idle. If the idle steadies, it idles around 2500rpms. Then it will surge and gradually increase in idle speed - nearing 3500. I hooked up diagnostic equipment and it gave codes for the MAF, TPS, IAT sensor, and the Water temp sensor. The exhaust smells very lean too. Has anyone had any issues like this? The only sensor on the new harness is the MAF and the pins to the ECU match on both auto and MTX harnesses
