Right now my EGR will not open i do not know why yet!Wich one is better ,make it work and let the exhoust gas go into the intake or let it not to open?Do wee need as much O2 as we can for the burning and cold air right.If i let the warm exhoust gas in the intake i will reduce both right.The othr question !I want to fix it anyway i have checked the EGR solenoid works ,pressure sensor works ,Egr passage clean and works to.The EGR solenoid will not switch to let vacum to egr .Can someone tell me wich wire what do if i check multimeter?I have 2 wires at solenoid ,what volt suppose go trough wich wire ,i have i1 12 volt the other one i do not know( i assume it should switch to ground )that is where i am stuck ,i think something not right at that point.Sorry for english i am from EU.
