Big Jim
Like I said, copper refers to the CORE, not the entire center wire. Copper IS NOT exposed to the combustion chamber. It would be like the movie "Gone in 60 seconds".
I did not elaborate on the alloy of steel used on most copper core plugs, but it is not pure nickel.
Something else you need to be aware of. The platinum tip originally was only on the firing electrode. That is not always the center electrode. On engines with coil packs, like ours, half of the engine fires from the center electrode to the side wire, while the other half of the engine fires with reverse polarity. When Ford first introduced platinum plugs for common use, it was on a coil pack engine. The factory installed plugs had the platinum button on the firing electrode only. Half of the plugs had the platinum button on the center wire, and half of them had the platinum button on the side wire. Replacement plugs were dual platinum, with a platinum button on each tip to make them idiot proof so that they would not be accidentally installed in the wrong cylinder.
Platinum is not the only long life metal for spark plugs as you know. Iridium is getting more and more common, often with platinum on one tip and iridium on the other.
The biggest concern on plug life is the metal on the firing electrode. The receiving tip is not as critical, as it is the firing tip that erodes away with use. That is why single platinum plugs (with steel alloy side wires) work well and last well on engines that all cylinders fire conventionally.
Back to the original topic. I still view plasma plugs as snake oil. The dyno figures are not significant. The variance is within statistical range. What snake oil companies often do, is pay for several double blind tests until they find one in which they came out on top and then they publish that while ignoring the rest. Even if the test has validity and integrity, the difference just isn't significant.
