getsum111
Yes I am a Pirate, 200 years too late.
Hello all. I have a question for the electrical/audio gurus. A couple weeks ago, my radio began turning itself on after I had turned off the key and removed the key from the ignition. FWIW, I am using a wiring harness to the factory wiring for the 12V, ground, and Mem wires. I ran a remote wire from the HU to the trunk for my amps, and 2 RCA's from the HU to the amps.
Fiddling around with my multimeter, I have found that the 12V wire, which only used to have voltage when the key was on, now has voltage all the time. :shrug: I have made no changes to any of my wiring, and I'm not experiencing any other issues that I know of.
I traced back the wire through the dash as far as I could, and saw no places where it seems shorted. But even if it is nicked somewhere, why is there voltage going to it now, when then was not before?
I can run a new 12V source to the HU, I'm more concerned about leaving a wire somewhere that is shorting/grounded out, draining the battery. Any ideas on where to start looking/testing? All the wires look fine to me. Thanks all.
