So I've got the O2 sensor code, P1151 but when I scanned for the non-continuously monitored data, found some misfire info. Before I just get a new O2 sensor, should I be looking elsewhere for other problems? Wouldn't that O2 sensor control three cylinders?
p1151 Lack of HO2S21 Switches - Sensor Indicates Lean (see P2197)
$25 EVAPRISEL4 value -64 FAIL
Evaporative Maximum Vapor Generation Rise Limit phase 4 is -64.000 inches of water with minimum limit of 3.000 has FAILED
$51 MIS8B 100% FAIL
Misfire Type B Emission Cylinder 8 is 100.00 percent with a maximum limit of 3.90 has FAILED
$51 MIS7B 100% FAIL
Misfire Type B Emission Cylinder 7 is 100.00 percent with a maximum limit of 3.90 has FAILED
$52 MISMONMIN 1451 cts FAIL
Miisfire Event Monitor Consecutive Events is 33105 counts with maximum limit of 0 has FAILED
$51 MIS8B 100% FAIL
$51 MIS7B 100% FAIL
