jimbbski
First I want to say that I just finished a number of projects on the engine and now it won't start.
#1. I removed the upper & lower intake to replace the gaskets and to clean the intake runners.
#2.. I replaced Bank #1 O2 sensor.
#3. I replaced the water pump.
#4. I replaced the plug wires with Motorcraft OEM style wires.
#5. I replaced the thermostat.
After I got everthing back together I tried to crank the engine and got a no crank. I removed the battery ternimals and cleaned them and re-installed the connections. I then got the engine to crank but still no start. I double checked the firing order and found I switched #5 & #6. I corrected that and still no fire. I haven't check for spark at the plug yet. I will do that tomorrow as I am just to tired to work on it anymore today. I also will get a code reader to help figure out what is wrong.
Any suggestions as to what to check or what might have gone wrong would be appreciated.
I do like this car and enjoy driving it but working on the engine sucks and then when I have a problem like this it double sucks!
