hmouta
so for a few days now i get a humming/droning that starts around 15-20mph and up to 70ish. seems to die down after that. though maybe i cant hear it cuz engine is getting louder. thought it might be some kind of moosing but it would go away from blipping the throttle (like my previous moosing). thought it was tire noise but driving with window open i can hear the driver tire and the noise doesnt seem to be coming from there. it really sounds like its coming from directly in front of me in engine bay. cant be the intake since the noise doesnt appear when the car is parked and i rev it up.
starting thinking wheel bearing but doesnt that only appear when turning? i have heard the slightest squeal when i'm doing a full right turn, but thought it sounded like the tire giving the squeal. i put in the koni kit last fall and was careful to not pull the axle out of the tranny. the halfshafts are splined so they would naturally set themselves back in the grooves even if i did pull it out a bit, right? could i have pushed down the control arm too far to mess up the axle or somehow the wheel bearing? would a bad wheel bearing make a humming noise while driving straight? i'm gonna do the wheel in the air shake test this weekend.
obviously i want to fix this but can it go a few more weeks if it is a bad wheel bearing or axle? i was going to redo my alignment in april before putting on my 18s. might as well wait to take the hub apart until just before i go for the alignment.
